kengordon
0
Broadband usage figures crazy
Hi there,
We've only just signed up to BT for Option 1 broadband and telephone.
The Broadband went active on March 7th. Yesterday i received an email to say we'd exceeded 7GB of our 10 GB monthly allowance.
We have one desktop PC and one laptop linked to the Home Hub, do not download anything and according to the BT usage listing, shold have consumed at most 2 - 3GB to date.
Last night I registered withe BT online paperless account service and was able to read my broadband useage directly from the website.
This morning before I went to work at 0700, the useage was 8.38GB, when i checked after returning home it was 9.46GB. More than 1GB has been added when no-one was at home and both PCs were switched off. No one else has the Home Hub key code.
Early tonight I phoned 0800 111 4567 and got through to Broadband technical support who said they had no way of checking what was going on with my line. They passed me to billing. The lady in billing went away for a long time to talk to technical people and advised that there might be an error in the settings and the value displayed might be wrong. She said BT would know when the bill is generated on April 1.
I asked how would they know? She said maybe someone elses useage has been added by mistake. When i aksed how would BT know, she could not answer me.
She suggested waiting 48 hours to see if the broadband useage number goes down and that the 7GB was maybe correct. When i asked how she knew the 7GB was correct, she could not answer me.
I have had a BT account for less than 30 days. Reading the comments in this forum and elsewhere on the internet it would appear that I am not alone in having phantom useage figures and my confidence in BT is now thoroughly gone.
I don't want to wait 48 hours to find the usage has just gone up further and then have to spend another 30 mnutes on the phone while someone else doesn't get to the root of the problem. The lady today was perhaps doing the best she could but in the end i think she just wanted me off the line.
I won't wait until April 1st to see if the actual billing is corrected becaue ibelive no-one i spoke to this evening cared or could help. If this goes on, i am facing extra billing costs on useage that does not exist and i am concerned that BT has no will or way to work out what is going on.
Will cancel the account in the next 48 hours unless i get some sort of fix,someone sounds like they know what is going on and gives me some confidence that the problem will be fixed.
Can you help?
K
Guru
Andy_N
0
Re: Broadband usage figures crazy
kengordon wrote:
Hi there,
Can you help?
K
Hi. Welcome to the forums.
Something doesn't sound right with your usage monitor figures. However .....
Just for info, the online meter is a day in arrears. When you checked at 7am, it may probably have been showing the usage up until 15th March. Checking later would have got the up to date figure but for usage up until 23:59 on 16th March, in other words not live figures.
You say you don't download anything, but do you use iPlayer type access, or facebook applications, youtube etc ? All of these services can seriously eat up the usage. iPlayer (or other TV streaming) can use anything between 500MB and 1GB per hour. Some facebook applications/games have been know to use many 100s of MB per day. Youtube can also use a lot if viewing many items, particularly in highest definition versions.
Also note that uploads are also included in the usage figures. (e.g. sending photos to photo sharing sites such as flickr).
kengordon
0
Thank you for the prompt reply.
Ok, I understand that the broadband "meter" is in arrears, that is very useful to know. By your reasoning that means 1GB was used yesterday. Given the day today when nothing was switched on, I would expect that the figure tomorrow to be not appreciably higher.
When is the best time to check? After mid-day?
Obviously being alarmed at the figures i have been round the machines, switching them on and have checked for running programmes, viruses etc.
Thanks also for your comment on the use of iPlayer & TV streaming (can use anything between 500MB and 1GB per hour).
We don't use either.
BTW I'm probably missing something but the figures you quote are at variance with the table on your website that states "Streaming 30 minutes of SD video (at 800kb\s)" uses 175MB. You will understand that I've been having a good look through that table given what has happened.
Again useful to know about Facebook applications/games.
Facebook is hardly used in our house. Same goes for Youtube.
So thanks for your speedy reponses and the useful information but we don't use any of the programmes / services listed in any significant way.
That brings me back to now 9.46GB of useage that I'm sure can't be ours and the strong impression that BT have no way of getting to the bottom of what is going on. What now?
Best regards
K
Expert
hamish72
0
I believe it updates around midnight so unless you have very long shifts the figures you saw for am and pm should be the same if I am correct about update times
Might be worth checking the data used in the hub stats as long as it has been on continuosly
Hope you changed the wifi code from the default if it still comes printed on the hub incase its visable to anyone
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
kengordon
0
Thank you sir.
I haven't changed the wifi code from the one on the sticker. Not sure how to do that.
I'm new to BT and Hubs, so sorry for a newbie type question.
How do I check the data used in the hub stats?
Best regards
K
Expert
hamish72
0
[ Edited ]
enter in browser to change wifi pass
http://bthomehub/wireless.lp?be=0&l0=2&l1=0&l2=-1
hub pass will be needed or it will ask you to set one
http://bthomehub/bb_internet.lp?be=1&l2=0&l0=2&l1=2        for hub useage
kengordon
0
Thank you for your help. Much appreciated.
With no hub data to check usage, I suppose that means I can't check activity myself.
Can BT I wonder?
All this is happening in the 2 week "settling period" while the broadband glue dries. Do you think this has anything to do with it?
best regards
K
Expert
hamish72
0
SEEE my edit I found the link which shows the data up and down
kengordon
0
Ah. getting 403 Forbidden when i use that string.
K
Expert
hamish72
0
Dont know why but enter enter for homehub
192.168.1.254 in browser if nthat bgets you in to hub page then top riht a to z listing
which hub do you have ?
