Message 11 of 23
Re: BT Hub 4
@cityangel
What does your master phone socket look like?
Message 12 of 23
Re: BT Hub 4
It looks more like 7 its says Openreach MK4 at top , right hand slot has a phone shape underneath it and left one some stars ?
Tried to attach picture but it says file too big?
Message 13 of 23
Re: BT Hub 4
The Mk4 just means the filter, which just unclips.
These do suffer from intermittent faults.
Can you try connecting things up as shown below, and leave it like that and see if you still get the disconnections. You will need  to unclip the front, and use a microfilter plugged into the test socket.
NTE 5C Test socket checkNTE 5C Test socket checkNTE 5C Test socket check
Message 14 of 23
Re: BT Hub 4
Where do i get the microfilter bit from?
Message 15 of 23
Re: BT Hub 4
They would normally have been supplied with the home hub 4. BT used to send two microfilters, they may still be in the box that the home hub came in. Similar to this.
Message 16 of 23
Re: BT Hub 4
I don't have the box the hub came in, got this bt hub about 7 years ago lol
Message 17 of 23
Re: BT Hub 4
as @Keith_Beddoe posted you would have used filters prior to getting the filtered master with 2 outlets  you may well have just put the filter in a drawer somewhere just in case needed in future
Message 18 of 23
Re: BT Hub 4
The bt man who fitted the last socket took all the bits away with him, I know I'm over 65 but I don't have one of them, trust me
Message 19 of 23
Re: BT Hub 4
unfortunately you need a filter before you can use the test socket so can't test to see if problem internal or external.  the type of master you have often can get dislodged very slightly if knocked so check that front is securely clipped in place
Message 20 of 23
Re: BT Hub 4
@cityangel
What you can do, is to unclip the front, then clip it back on and see if its secure.
This post explains the issue.
https://community.bt.com/t5/Landline/2019-Master-Socket-kit-loose/m-p/1985566#M67755
If you would prefer to try it with a microfilter, they are readily available at minimal cost. I expect the Openreach person who visited has quite a stock now, I wonder what they do with them, I could guess.
