Message 2 of 12
1-3mbps broadband
Hi all,
I'm looking at moving to a flat & have just been told that I can only get speed of 1-3mbps. I was shocked at this but due to the location nothing can do about it.
Is this speed accurate & has anyone any experience with broadband this low?
Will I be able to stream Netflix BT TV, BT sport & all other stuff used with broadband?
Any help & advice much appreciated.
11 REPLIES 11
Message 1 of 12
Broadband speed
Hi all,
Im looking at moving to a flat but have just been to check broadband deals & I've been quoted that the speed is 1-3mbps is as good as I can get due to location of the flat.
Has anyone had broadband this low before & are the BT speed checkers accurate for this low speed?
Message 3 of 12
Re: 1-3mbps broadband
That is drastically low speed and will be pretty much useless for Netflix etc.
Message 4 of 12
That's what I was thinking.
I've been offered the Hybrid connect aswell as the broadband hub. This takes over when broadband cuts out & uses the 4G network.
I don't know anything about it tho
Message 5 of 12
@Dizzie40 welcome to the community and thanks for posting.
What results do you get if you enter your details on this availability checker?
Neil
Message 6 of 12
As it will only take over when your broadband fails, it doesn't help you much.
Have you considered 4G broadband?
Message 7 of 12
I've just been looking at 4G broadband the coverage for the area seems ok with EE & 3. EE very expensive tho. 3 seems good prices but coverage is average. Do you know anything about 4G broadband?
Message 8 of 12
Thanks I checked & shows only 1-3mbps I'm afraid. Do you know much about 4G broadband?
Message 9 of 12
This may be of help https://www.bt.com/broadband/USO
Message 10 of 12
@Dizzie40 4G broadband is basically a slightly more powerful mobile receiver that either plugs into a PC etc or a hub. It connects to the 4 or 5G network to give you a usable internet connection. The costs are normally higher but cheaper than paying for an infrastructure upgrade. If you run a speed test on a 4 or 5G mobile, you'll get an idea of what speeds you'll be able to get.
Another option is a Starlink satellite connection but that'll cost about £90 per month plus £500 for the kit and a connection fee.
