Message 1 of 3
Full Fibre alternative?
Openreach are unable to get the fibre cable to my house because the duct beneath my (brand new) driveway has been crushed.
1. How long Can I hold onto regular broadband? And seeing as I need to renew my contract atm, who will sell me a regular broadband package?
2. If openreach had to dig up my driveway to repair the duct that carried their fibre cable, would they make it good afterwards? Or do I have to get that driveway repaired once they’re done?
many thanks for any replies in advance, Stu
2 REPLIES 2
Message 2 of 3
Re: Full Fibre alternative?
1. Provided you don’t renew your ‘contract’ or move to another provider (both events likely to require taking FTTP ) you can stay on the copper pair service for a while , possibly years , there is no way to know exactly but there no imminent risk to your copper service being removed, if the exchange is not a FTTP priority one then you may find a new copper broadband supplier , but most will offer FTTP as the default now it’s showing as available.
2.Yes any repairs to duct the ground excavated is reinstated , with some surfaces this may leave little or no evidence (like block paving for example, relaying the blocks should leave no evidence of then being lifted in the first place )  , but other surfaces like imprinted concrete or resin bonded can’t be restored invisibly so a scar/witness marks are inevitable and you won’t get the entire driveway replaced, if this is ‘new’  work , it’s likely they damaged the duct , you could ask them to return and fix the damaged duct  or agree to replace the driveway  once OR clear the duct stoppage.
Message 3 of 3
Great, thanks for the reply. Helped clear up my way forward.
