Message 1 of 11
Landline options
I have ADSL broadband and a landline.
There is no fibre in this area, so I needed to find a solution for when the copper-based systems are switched off. For broadband, I now have EE mobile broadband which works well enough.
For the phone, I've been getting conflicting information. Today, I was told that I can continue with my copper-based landline for £3/month and all calls are chargeable. That's fine, I use mobile for all my calls but would like to keep the landline.... I've had it for over 30 years and I want to ensure that anyone I've given my numer to over the past 30 years can still contact me.
Is it really true that my copper-based landline will continue after January 27? I don't want to find it suddenly doesn't work and I lose my number
10 REPLIES 10
Message 2 of 11
Re: Landline options
Digital Voice does not require Fibre. The copper network is not being  discontinued.
Message 3 of 11
Unfortunately, the media got this confused and has caused a lot of misunderstanding.
At present the PSTN (Public Switched Telephone Network) shares the copper lines as a separate service.  It is this that is coming to an end by January.
Now the phone service has to be delivered as part of the broadband.  However, that broadband can be delivered over copper or fibre.
Copper-based broadband is being phased out, but gradually, between now and 2040.  In some areas you may have to upgrade to fibre, but obviously that is only possible where it is available.  Other areas will continue with copper for the foreseeable.
Phone-wise…it makes absolutely no difference to Digital Voice whether it is copper or fibre.  (I know.  I’ve just spent 2 years with Digital Voice being delivered via copper-based broadband and the last 12 months with it being delivered over fibre.  Phone works the same for both).
Message 4 of 11
Hence my confusion. The BT Helpline said I could just leave the phone as-is and I don't need to move to Voip. Didn't sound right.
Message 5 of 11
If you genuinely have ADSL (exchange based broadband) then anecdotal evidence suggests  DV (digital voice ) isn’t available and a more convoluted arrangement needed , the existing line converted to a pre digital phone line and a second line provided for broadband, supplied by EE , both services supplied for the same price as a regular broadband/telephone service.
FYI , £3 is the price of the call plan (in this case a PAYG calls plan ) and not the cost of the telephony service .
As stated , it’s only PSTN telephony that’s being retired in January 2027 not ‘copper pair lines’ , but if your are on ADSL rather than FTTC , then I suspect you possibly are misunderstanding what’s needed to keep your broadband and telephony working , if your mobile broadband is sufficient and you have elected to only have a landline style telephone service with no landline broadband that’s different but it won’t cost £3 .
Message 6 of 11
BT themselves haven't helped this confusion by keep saying in their DV publicity that "the copper lines are being retired". They are but only very slowly as and when fibre can be put in instead and certainly not by Jan 2027.
Then the media has picked this up and proclaimed "BT is ripping out all its copper lines by Jan 2027".
That isn't going to happen and, if you have broadband over an ADSL connection using copper lines, that will continue to work, as will DV over that broadband connection.
Message 7 of 11
Message 8 of 11
Just reading this.. understand the need to separate the services, but why EE Broadband and not BT. In these ADSL cases, must the broadband be from a different supplier to the DV enabled service then? And if so, why?
Message 9 of 11
I suspect it is down to the physical locations of the DSLAM and PDLP kit and exchange closures.
Message 10 of 11
There is no DV in these cases , PDPL isn’t DV (BT call PDPL ‘home phone standard’ , PDPL is what the supplier BTw call the product they offer to CP’s ) .
As to why the BT ADSL service is removed from the existing ‘line’ allowing it to be converted to PDPL , but BT ADSL isn’t simply reinstalled on the new additional copper pair , but EE broadband is provided on the new ‘line’ , who knows ? , perhaps it is as @licquorice  states , perhaps it’s easier to manipulate the billing with separate ISP’s , or perhaps EE broadband is ADSL2+ (24Mb theoretical max) and the BT existing service is only ADSL (8Mb max) , the rationale AFAIK, hasn’t been made public .
