Message 1 of 4
OpenWrt BT Broadband configuration.
Hi All. I want to replace my HomeHub-3 with an OpenWrt-One connected to my existing Openreach Modem( NGA ECI-CPE-MODEMS TYPE 1B, model B-FOCuS V-2FUb/r Rev.B).
I need to confirm the router configuration details for my BT Broadband ADSL connection.
BT technical support could not supply any information except 'username = [email protected]'.
I have been trying various unsuccessful modifications of examples found here https://openwrt.org/docs/guide-user/network/wan/isp-configurations
Any thoughts appreciated - thanks, null.
3 REPLIES 3
Message 2 of 4
Re: OpenWrt BT Broadband configuration.
With the ECI modem all you need on the router is the username "[email protected]", password "BT" and a the connection type set to PPPoA or PPPoE - on most (not all) exchanges, either will work!  Everything else is handled within the modem.
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 4
Crimliar - that worked, brilliant, thanks - null.
Message 4 of 4
Good luck with the setup.  After a great deal of research, I'll probably head down the OpenWRT route myself (I have a test rig already), but it's quite a learning curve!
