Message 1 of 2
Security Concerns
I am concerned with recent activity on my broadband service. been told I have to wait 1 hour 30 minutes on getting to speak to someone. my bt hub manager showed 20 (TWENTY) devices connected to my hub, while I have 3 max. So I started deleting the ones that were not mine, then it stated that these devices are controlled by the app even though I did not have the app installed or used my phone to use the hub manager.
D. Lemon, Fife.
1 REPLY 1
Message 2 of 2
Re: Security Concerns
Hi @dlemon73,
Welcome to the BT Community
Hopefully you have been able to speak to one of our team since your post. I can understand being concerned when it comes to the safety of your connection.
It is not unusual for the list of devices to be higher than you use, as devices stored there will be devices that have connected historically, as well as any devices that have changed their address at any point, rather than being a list of currently active connections. If you are able to remove them it does mean they are currently disconnected from the router.
With some features, devices can only be managed via the BT app, mainly around Wi-Fi controls. I would recommend setting up the app if you have not already just so you can manage it that way also.
If you are concerned about your Wi-Fi connection you can also of course change the Wi-Fi password which will disconnect all wireless devices currently connected, then login back in on your devices with the new password.
Alex
