Message 1 of 5
Two BT Hubs in use simultaneously!
OK, i own up. I did buy a second hand 'new' BT Smart Hub 2 from eBay for £25 or thereabouts, in preparation for the eventual day when BT send me one officially for DV.
I have configured it with the same credentials as my current Smart Hub Home 6, whatever it's called. What I would like to know is whether it is possible to have both in action at the same time, as I have a spare extension socket where I could plug in an ADSL cable and power it up.
Would there be any problems or interactions having two on the same ADSL  feed?
Have I overlooked some glaringly obvious reason why I should not?
4 REPLIES 4
Message 2 of 5
Re: Two BT Hubs in use simultaneously!
No. You can only have 1  homehub connected.
Message 3 of 5
Presumably if I turn one off before booting up the second one (latest one) that would be OK?
Message 4 of 5
Yes but be aware that repeated on and offs could cause DLM to read that as a fault and lower your speeds to try and get a stable connection.
Message 5 of 5
Yes, I'm aware of that problem. I only wanted to test out the SH2 for a few hours or even leave it on overnight to see whether there were any updates.
Was also interested in 'phone not configured' or greyed out but considering I don't have DV yet, that's not surprising.
