Message 11 of 12
Re: how can i tell witch type bt broadband service we using copper to copper or FTTC
Thanks  Clara net is my ISP not BT  just using bt copper and fiber network  Netgear modem roter ADSL2+  VDSL  has been in place  16 year work fine, only have problems if bt  open up old gpo link box in the  west street  wareham
Message 12 of 12
BT do not have a copper and fibre network. The network is operated by Openreach.
This is a BT residential forum which has nothing to do with Openreach.
You should contact your own Internet provider, Clara and they will tell you what type of broadband you are currently on.
If you want to change to BT Broadband as your ISP then just look at the following link and select a package. If your address can not have the package it will not allow you to order it.
https://www.bt.com/broadband
