Message 1 of 4
Net disconnects, followed by speed lowered significantly, despite normal latency
Hello folks!
A typical symptom of my net, going back years, is that it'll disconnect and reconnect at a third of the speed with HIGH latency. Historically, a basic reset of the router fixed that every time.
However, now it seems that 'fix' doesn't work.
> net disconnects every couple hours
> reconnects at <20mbps with normal latency
> both Ethernet and WiFi impacted
I've tried 3 routers and multiple adapters.
What else can I do to troubleshoot this myself, please? Before I go down the engineer route and have them spend an hour trying to convince me it's the walls in my house causing it, etc
Thank you very much
3 REPLIES 3
Message 2 of 4
Re: Net disconnects, followed by speed lowered significantly, despite normal latency
if your router is dropping internet connection as often as every few hours then there is  a line problem  provided you don't have digital voice have you tried dialling 17070 option 2  should be silent and nay noise is a problem and need reporting as a fault to BT
constant drops in connection will result in DLM taking action to stabilise your line by increasing noise margin and reducing connection speed
Message 3 of 4
Thanks for getting back to me.
As of approx 2 weeks ago, I no longer have a landline, nor digital voice. Unsure of next steps.
Message 4 of 4
if you have tried connecting hub direct to the test socket with a filter and you still get the disconnects then you need to report a fault to CS 03301234150
