Message 1 of 2
How to remove a "solved" tick in the forum
How can I remove a "solved" tick against my recent post in the forum?  It has been applied by someone - not me - when the answer has NOT been given.  I need to remove the tick and invite more responses.  Otherwise I shall have to repost with the same question.
Tags (1)
1 REPLY 1
Message 2 of 2
Re: How to remove a "solved" tick in the forum
go to the solution post and 3 dots top right scroll down and unmark as accepted solution
