Message 1 of 9
Job application
Hello I am Ajay, I have applied for a apprentice customer advisor role which was advertised at talent.studysmarter by BT. I just am wondering how long is the wait for the results of I am in or not because when I looked up it says 24 hours but it's been 24 hours since I applied and got no response back and sorry just don't know if it's accepted or rejected. Please kindly help.
8 REPLIES 8
Message 2 of 9
Re: Job application
@Ajay3
This is not the place for job applications for BT, it’s a domestic residential customer to customer forum.
Call or email whichever department you applied to because no one here can help you with your job application.
Message 3 of 9
Re: Job application
I don't clearly know what department it's for but I think it comes under the customer service department as it's a customer advisor role and can you please tell me what email should I contact on if possible and thank you.
Message 4 of 9
Re: Job application
@Ajay3
You could try:
[email protected]
Or this:
https://jobs.bt.com/
But not on this forum, it isn’t a BT jobs application portal. Any other information you can find by simply doing a Google search.
Message 5 of 9
Re: Job application
Thank you!
Message 6 of 9
Re: Job application
Hi @Ajay3
As others have mentioned this forum  purpose is
The BT Community forum is a support forum whereby BT customers can interact with other BT customers with the aim of either seeking help and advice or offering expertise to help other customers. The goal of our forum is to give customers an arena to share their expertise and experience with one another.
Now there is enquiry point at
https://www.bt.com/about/contact-bt/careers-enquiries
Message 7 of 9
Re: Job application
@zulu17
If you’d read the OP’s post, they’ve already applied for a job but they need a suitable email to check in their application.
They’re probably supposed to manage their job application through the appropriate job portal but they’ve seemingly failed to do so.
Message 8 of 9
Re: Job application
Thank you!, appreciate that.
Message 9 of 9
Re: Job application
@Kimberlin @zulu17 ...Zulu17's recommendation was exactly the right place if he doesn't know the appropriate portal.
