Message 11 of 17
Re: 1571 voicemail - is it included with digital or charged extra ?
No you're not. 1571 is free on Digital Voice
Message 12 of 17
Perhaps its that way if you do not have a calls package?
Message 13 of 17
The 35p is usually the charge for pressing "x" to return the call
Message 14 of 17
So, if I only listen to a 1571 message it is free?
Message 15 of 17
yes
Message 16 of 17
Message 17 of 17
my  hub is in my office on a data extension so the main socket is in the hall ,i have a existing phone socket  that is not in use so i bought a male to male  phone extension lead from ebay for a few pounds and then plugged that into the back of the hub  and the other end into the unused phone socket ......and hey presto all the old house phones AND existing answering machine are working
