Message 1 of 7
4g mini hub speed throttling
For almost 3 weeks my FTTP broadband is down, so BT finally sent me 4g mini hub to keep me connected. I tried it and see that I get always steady 30/15(DL/UL) speeds during the day . Having put an EE sim in there (BT uses the same network) I get varied results but around 50/50 generally. In the late evenings speeds do improve to about 80/70 on both SIMs, so this makes me think that BT is doing throttling on their SIMs during the day (or EE is doing that for them). I did ask tech support if they do throttling and they said - no.
Has anyone experienced the same? Download is OK, but we barely survive on 15mbps upload speeds working from home full time as the whole family...
6 REPLIES 6
Message 2 of 7
Re: 4g mini hub speed throttling
Just guessing, but I suspect the 2 Sims use different backhaul networks with different levels of congestion/contention rather than deliberate throttling.
Message 3 of 7
I did think  of that, but the BT speeds are too consistent to be congested. Sometime I can see bursts of 40-50 in the first couple of seconds and it always comes back to 30. Proper SQM type of throttling...
Message 4 of 7
BT Mobile speeds are capped at around 30mbps unless you have the speed boost bolt on and then it's uncapped. The bolt on is normally included in Halo packages if you're a BT Mobile customer
Message 5 of 7
That would have explained it, but I run the test now and its 77/46 on BT SIM. Not sure when is the exact cut off time as the speed only goes up after a reconnect during off peak hours... I will chat to mobile helpdesk tomorrow.
Message 6 of 7
@NigelB72Do you have a link for that?
