Message 1 of 5
5 Openreach engineers, 1 new socket, 2 new faceplates and 1 replacement smart hub 2 later...
Hi
Hoping someone here can help with the issue I've been having for the past 6 months, though I've seen a lot of posts on this subject.
Long story short:
Moved from Virgin to BT in February 2020, since then I've had nothing but problems maintaining a stable connection. Main problem is the speed of the line slowing down, I have a 50Mb contract, after two weeks I'm down to 25Mb or worse. Log call with BT, Openreach engineer arrives, checks line, all good, boosts speed back up, sure enough 2 weeks later its back down again, I am also suffering multiple disconnections, today I've had 10 in the last 4 hours, usual flashing lights then back to blue.
I'm now having to work from home due to a bereavement and a parent with the early stage of dementia so need my connection to work. Strangely enough I have the exact same package and smart hub in my own flat in London and do not have any of the problems I suffer here in the outskirts of a small city in the east of England.
List of works so far:
1 new socket installed at time of move from VM to BT. Its the only working socket in the house.
2 new faceplates by OR engineers
After much arguing with BT a new Smart Hub 2 was sent and installed to rule out device issues.
Not much connected to the Wi-Fi, 2 laptops and nothing else as BT were accusing my devices of causing the problems.
Line test has come back clear (OR engineers check this first, I've also run my own tests which came back clear, no noise). I've wi-fi sniffed networks near me but there are very few and none using the channels I'm on so no clashes
I've disabled smart setup and enabled and disabled the smart scan function to no avail.
Details from the new hub (I've removed mac addy and wifi name from below) - its been 2 days now since they boosted the speed back up...and its dropped to below 40Mb already..
Product code:Smart Hub 2
Serial number:+091298+2030029387
Firmware version:v0.17.01.12312-BT
Firmware updated:Fri Sep 18 13:25:51 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,00 Hours25 Mins52 Secs
Data rate:9.946 Mbps / 39.973 Mbps
Maximum data rate:10.079 Mbps / 48.104 Mbps
Noise margin:6.3 / 9.9
Line attenuation:6.5 / 20.7
Signal attenuation:6.6 / 19.6
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:3.1 MB Uploaded  / 11.2 MB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:
2.4 GHz wireless channel:Channel: 1
5 GHz wireless network name:
5 GHz wireless channel:Channel: 40
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
This is what the error log records when a disconnection happens:
11:49:24, 21 Sep.
SIP WAN UP
11:49:15, 21 Sep.
NTP synchronization success
11:49:15, 21 Sep.
NTP Server: ntp.homehub.btopenworld.com
11:49:03, 21 Sep.
WAN Sensing Auto sensing Complete, interface selected
11:49:03, 21 Sep.
WAN Sensing Auto sensing Running
11:49:02, 21 Sep.
DSL Link Up: Down Rate=39973kbps, Up Rate=9946kbps; SNR Margin Down=9.8dB, Up=6.0dB
11:49:02, 21 Sep.
NTP synchronization start
11:49:02, 21 Sep.
11:49:02, 21 Sep.
WAN IPv6 Global unicast prefix / length: 2a00:23c4:1599:1d00::/56
11:49:02, 21 Sep.
WAN IPv6 Global unicast address allocated: 2a00:23c4:1599:1d00::1/64
11:49:02, 21 Sep.
WAN DHCPv6 events: BOUND
11:49:01, 21 Sep.
11:49:01, 21 Sep.
Success - secondary DNS servers
11:49:01, 21 Sep.
Success - primary DNS servers
11:49:01, 21 Sep.
WAN connection WAN2_INTERNET_PTM connected
11:49:01, 21 Sep.
WAN DHCPv6 events: INIT
11:49:01, 21 Sep.
PPP: IPCP up
11:49:01, 21 Sep.
PPP IPCP Receive Configuration ACK
11:49:01, 21 Sep.
PPP IPV6CP Receive Configuration ACK
11:49:01, 21 Sep.
PPP IPCP Send Configuration Request
11:49:01, 21 Sep.
PPP IPCP Receive Configuration NAK
PPP IPCP Receive Configuration Request
11:49:01, 21 Sep.
PPP IPV6CP Send Configuration ACK
11:49:01, 21 Sep.
PPP IPV6CP Receive Configuration Request
11:49:01, 21 Sep.
PPP IPV6CP Send Configuration Request
11:49:00, 21 Sep.
11:49:00, 21 Sep.
PPP: CHAP authentication succeeded
11:49:00, 21 Sep.
PPP CHAP Receive success : authentication successful
11:49:00, 21 Sep.
PPP CHAP Receive Challenge
11:49:00, 21 Sep.
PPP: LCP up
11:49:00, 21 Sep.
PPP LCP Receive Configuration ACK
11:49:00, 21 Sep.
PPP LCP Send Configuration ACK
11:49:00, 21 Sep.
PPP LCP Receive Configuration Request
11:49:00, 21 Sep.
PPP LCP Send Configuration Request
11:49:00, 21 Sep.
PPP: Received PADS
11:49:00, 21 Sep.
PPP: Sending PADR
11:49:00, 21 Sep.
PPP: Received PADO
11:49:00, 21 Sep.
PPP: Sending PADI
11:48:55, 21 Sep.
PPP: Starting PPP daemon
11:48:54, 21 Sep.
WAN Auto-sensing detected port DSL WAN
11:48:31, 21 Sep.
SIP WAN DOWN
11:48:28, 21 Sep.
SIP WAN DOWN
4 REPLIES 4
Message 2 of 5
Re: 5 Openreach engineers, 1 new socket, 2 new faceplates and 1 replacement smart hub 2 later...
@Realistic_pessimist
1st question based on: "Not much connected to the Wi-Fi, 2 laptops and nothing else as BT were accusing my devices of causing the problems."
How are you performing the speed tests?  Wireless or Wired?  If Wireless then you will be unlikely to get close to the top speed.  Wireless is renowned for having speed issues.  You could try changing WiFi channels and findint the one with the best speed.   Can you (if you haven't) perform a wired speed test?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 3 of 5
Tried both, OR engineers have done the same.
The speed starts in the high 40's then over a period of 2 weeks drops to well below the stated line speed, regardless of the connection (and to be honest even if it was wireless I wouldn't expect the drop to be so dramatic though I take your point). I should add the speed doesn't increase until someone resets it. The last OR engineer showed me the graph over a period of time and you can see the gradual decrease. He said the system was designed to constantly drop the speed if it thinks there are problems on the line until it finds a speed its happy with. Thing is there are no problems on the line according to 5 OR engineers...
Message 4 of 5
can you enter your phone number and post results  remember delete number  will show estimated connection speed range    https://www.broadbandchecker.btwholesale.com/#/ADSL
Have you tried the test socket with a filter to see if that helps stability?
Message 5 of 5
Socket filter in socket filter out, two faceplates changed as well to no avail...
Telephone Number on Exchange is served by Cabinet 16
Featured Products
Downstream Line Rate(Mbps)Upstream Line Rate (Mbps)Downstream HandbackWBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper
Threshold(Mbps)
HighLowHighLow
VDSL Range A (Clean) 48.736.910.66.134.6AvailableAvailable--
VDSL Range B (Impacted) 47.334.410.25.528.1AvailableAvailable--
Featured Products
Downstream Line Rate(Mbps)Upstream Line Rate (Mbps)Downstream Range (Mbps)Availability DateFTTP Install Process
FTTP on Demand33030--Available--
ADSL Products
Downstream Line Rate (Mbps)Upstream Line Rate (Mbps)Downstream Range(Mbps)ADSL Availability DateWBC SOADSL Availability DateLeft in Jumper
WBC ADSL 2+Up to 17--10 to 19.5AvailableAvailableYes
WBC ADSL2+ Annex MUp to 17Up to 1.510 to 19.5AvailableAvailableYes
ADSL MaxUp to 7.5--6.5 to 8AvailableAvailable--
WBC Fixed Rate2----AvailableAvailableYes
Fixed Rate2----Available----
Observed Speeds
VDSL
Max Observed Downstream Speed32.4
Max Observed Upstream Speed0.8
Observed Date########
Other Offerings
Availability Date
VDSL MulticastAvailable
ADSL MulticastAvailable
Premise Environment
Status
Bridge TapN
VRIN
NTE FacePlateN
Last Test Date########
Exchange Product Restrictions
Status
FTTP Priority ExchangeN
WLR WithdrawalN
SOADSL RestrictionY
