Message 1 of 3
ADSL to Fibre Switch
Hi All,
Apologies if this is in the wrong forum.
We are currently on BT ADSL and are looking to switch over to Fibre (1 or essential). I was just wondering what the process is?
  1. Is it a straight forward switch?
  2. Will there be any downtime?
  We currently have a BT Smart Hub.
Thanks in advance
Jason
2 REPLIES 2
Message 2 of 3
Re: ADSL to Fibre Switch
Sould only be a short downtime while the engineer connects you to a port at the FTTC cab.
Message 3 of 3
The downtime depends on the Installation Engineers ability to count and follow Routing Records. Unfortunately that appears to be a dying skill these days.
