Message 11 of 13
Re: Add a second, ethernet hard-wired wi-fi router to a BT Hub2
@daiprichwrote:
I think he called the service Fastnet, but I probably mis-remembered.
You did! I think he called the service G.Fast. This is the BB technology from which you can get speeds up to 330 Meg (or 165 Meg on a capped product which Fibre 100 would be). This is an interim technology between the up to 80 Meg VDSL & the up to 1000+ Meg of FTTP (Full Fibre).
Message 12 of 13
It's not fastnet, it is G.Fast which is a different DSL protocol from VDSL (both FTTC) allowing speeds up to 330mbps.
Ooops, didn'e see @RobbieBaron 's post. He's spot on.
Message 13 of 13
@Keith_Beddoewrote:
@daiprich
What is BT Fastnet, is that a BT Business product?
Are you actually with https://fastnet.co.uk/fibre-business-broadband/
Also didn't understand what was he referring to for the moment.
