Message 1 of 3
Adding a second router.
Is it possible for me to add a second router to my network while using the BT Smart Hub 2? It doesn't have a WAN port so i'm not sure how i'd go about connecting it.
2 REPLIES 2
Message 2 of 3
Re: Adding a second router.
For what purpose?
You can use a second router as wireless access point by connecting LAN port to LAN port, but if want to create a completely separate sub network, the second router would need to have a WAN port.
Message 3 of 3
Oh that's good to know thanks, kind of new to all this.
