Message 1 of 12
Adsl to fibre 1 changeover.
I am currently using a tp link vr2100 modem on my adsl connection but changing to fttc next week. Can I just leave my to link modem connected for the changeover or should I connect the smarthub 2 (at least for the 10 day training period)?
11 REPLIES 11
Message 2 of 12
Re: Adsl to fibre 1 changeover.
As the VR2100 is a dual ADSL/VDSL router you can just leave it connected.
Message 3 of 12
Many thanks.
Message 4 of 12
You will need to change the config from a PPPoA connection to a PPPoE connection though.
Message 5 of 12
From the dropdown menu the only options are bt adsl or other, the only way to change pppoa to pppoe is to select other, is that correct?
Message 6 of 12
Is there not a BT VDSL option?
Message 7 of 12
strangely not, from the isp list they are all adsl connections except "other"
Message 8 of 12
When your service has been changed over next week, I would factory reset the TP link and then try the wizard. It might auto detect the VDSL signal rather than ADSL
Message 9 of 12
OK, thanks for your help.
Message 10 of 12
@mike101 Just had a quick look at the online Emulator. If it doesn't auto detect BT VDSL, use 'Other' and these settings.
