Message 1 of 6
Advice WIFI 6
Hi All,
I've recently purchased a new laptop with WIFI 6 and would like to get the full benefit of it.  I currently have Smarthub 2 connected on Infinity 2.  Please could I ask for some suggestions on the best (not necessarily the cheapest) way of adding WIFI 6 to my network?
Thanks in advance.
(Yes I know BT are working on a new router and it will probably be released the day after I make my purchase...)
5 REPLIES 5
Message 2 of 6
Re: Advice WIFI 6
The full benefit of wifi 6 being?
Message 3 of 6
Re: Advice WIFI 6
Message 4 of 6
Re: Advice WIFI 6
Connected to a broadband signal capped at 80Mbps!!
Message 5 of 6
Re: Advice WIFI 6
So the polite way to put it, is there is nothing to gain.
Save your money  😁
Message 6 of 6
Re: Advice WIFI 6
Exactly
