Message 1 of 7
BT App
What is the latest bt app version and once downloaded will it auto download a new version when one becomes available
6 REPLIES 6
Message 2 of 7
Re: BT App
Which BT app are you referring to as there are several?
Message 3 of 7
Re: BT App
I am talking about the My BT App
I have v8.15.3
I am try to use it to update the firmware on my mini discs which are at v0.20.0006221
it says in the app to go to settings and select upgrade firmware but that option doesn't exist on the android app i have
Message 4 of 7
Re: BT App
Deleted by poster - already answered.
Message 5 of 7
Re: BT App
That is the latest version and providing you have auto updates enabled, it will update. With regards to the mini discs, I don't use them so I'm not familiar with the update process.
Anonymous
Not applicable
Message 6 of 7
Re: BT App
Wholehome discs or Complete Wi-Fi? If wholehome then you need the Wholehome app not the MyBT app
Message 7 of 7
Re: BT App
i think its the complete Wi_fi - black smart hub2 and black mini discs if that helps
