Message 1 of 2
BT Cloud Updating
Does BT Cloud update folders when I delete files? ie. will files I delete on me PC also be deleted on BT Cloud?
1 REPLY 1
Message 2 of 2
Re: BT Cloud Updating
@Snark Welcome to the community and thanks for posting, it depends if you're backing up the file or syncing it across devices. Check out this link on how the BT Cloud works for more info.
Cheers
Neil
