Message 301 of 304
Re: Backup, Sync or both?
Message 302 of 304
@mumfie
If you have set it to backup selected folders then all files get backed up regardless of size.  However if you are trying to push files selectively to the cloud then there is a 2Gb file size limit.
Message 303 of 304
It is set to backup a single folder and child folders only. It worked ok with 21.4.10. Reinstalling 21.4.10 does not work because it automatically updates itself to 21.8.9.
Message 304 of 304
mumfie, thanks for the info, update done and seems ok.
