Message 1 of 2
BT Cloud - is it safe?
I can't work out what is going on with BT cloud. The post that peope refre to is 465 messages long and i can't work out what the current status is.
Can someone please give a simple update:
On BTcloud...
Is the data safe?
What can I do to make restart updates?
- btcloud says 'all files synced', but this is not true, the lasyt update was 8 days ago.
- neither automatic or manual updates are working
How can I get the app interface/client/dashboard back?
1 REPLY 1
Message 2 of 2
Re: BT Cloud - is it safe?
BT Cloud is a thousand times better than it used to be, and it's still rubbish. It's simply not reliable. If you need a reliable backup then BT Cloud is not for you. When you're system packs in you need a backup that you know is reliable. It's a shame, I have 1000Gig more or less empty. If only BT would let us use an FTP client it would be much more useful.
