Message 1 of 2
BT Cloud rendering machine unusable
BT Cloud gets worse by the day - it is now consuming so much system resources that if I want to do any work I have to kill the process. It doesn't actually seem to be doing much anyway. Directories I have on my backup list do get backed up but NOT the files within the directory. It is a complete shambles.
1 REPLY 1
Message 2 of 2
Re: BT Cloud rendering machine unusable
You are aware that the last update to the cloud app turned out to be such a bag of bolts that the under-grad who wrote it should have been fired and made to do the year again?
On top of that it should have been withdrawn but incredibly is still available for download.
OK maybe I am ranting a bit but not without good cause as you will see from this 1100 plus strong thread.
https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/BT-Cloud-Won-t-Start/td-p/2117275
