Message 1 of 8
BT Cloud - unexpected error
I have been using BT Cloud for ages and went through the terrible saga of it not working and deleting files.  However, its ben stable for a while - but the last couple of weeks its says
"an error occurred, the application cannot contiue and will be paused".  This is happening EVERY SINGLE DAY.  the only way to solve it is to exit BT cloud and the restart it - I cant do that every day!!
I am using 21.8.9 on W10
Anyone else experiencing the same thing?  driving me crazy
7 REPLIES 7
Message 2 of 8
Re: BT Cloud - unexpected error
I had the same thing, yes.
I fixed it by uninstalling and reinstalling, but whilst I don't get that error message any more, my backups don't work.
Terrible product. Kids at school could write something better.
Message 3 of 8
HI @opalset11  and @woolstons ,
Welcome and thanks for posting about the BT Cloud problem. I'm sorry you're having a few issues. @opalset11 can you please try the advice posted by @woolstons and let me know if that helps? If not then I'll get a case raised with our specialists to have this looked into for you.
Cheers
David
Message 4 of 8
Hi
I've been having a succession of 'unexpected error' messages for weeks when I've logged on and documents of  BT Cloud has not been backed up from July 2021! I know I should have checked but I back up with iCloud as well.
I have a ~ 9 year old desk top Mac running Mac OS Catalina 10.15.7. Can anyone advise  please?
Message 5 of 8
Same thing here this morning. Kept getting "an error occurred, the application cannot contiue and will be paused". I had to close BT Cloud and then re-start it several times, and eventually it "appeard" to work without the error message.
Message 6 of 8
Same problem for me. Suddenly started getting the dreaded "An unexpected error has occurred" message again. Had it for 3 days now.
Will try and uninstall and install trick and see if that makes a difference.
Message 7 of 8
After update to 22.12.11 I am also getting this problem, Windows 10 PC. Have tried re installing several times  is
anyone else having this issue ?
Derek
Message 8 of 8
Yes same error - but on WIN7 ...
