Message 1 of 3
BT Cloud
I accepted a BT Cloud software update about two weeks ago. It deleted the software from my Windows PC and has not worked since. I have tried uninstalling the BT Cloud client software and re-installing it but it still does not work. Have contacted the helpdesk but not received any help. Is anyone else experiencing this problem? Is there a fix?
2 REPLIES 2
Message 2 of 3
Re: BT Cloud
I am having exactly the same problem. Relying on OneDrive at the moment but would like my extra layer of backup.
Message 3 of 3
Re: BT Cloud
HI,
There is an ever expanding thread on issues with the latest BT Cloud update for Windows which can be found here BT Cloud Won't Start . You are not the only one having problems!
Ade
