Message 1 of 4
BT Cloud
After the update BT cloud ceases to work, and I get asked if I want to buy more data. I have just under a terabyte spare!!
Even if I say 'yes' the system doesn't work. This issue seems to have been around a long time! Where is the solution?
3 REPLIES 3
Message 2 of 4
Re: BT Cloud
That's an excellent question, unfortunately it's by no means original. Have you seen this thread which is over 1000 posts long (I kid you not)
https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/BT-Cloud-Won-t-Start/m-p/2117275#M40736
Message 3 of 4
Re: BT Cloud
Thanks. I would have thought it would have been solved by now!
Message 4 of 4
Re: BT Cloud
I know, I keep checking every now and then as well but no sign so far
