Message 11 of 12
Re: BT Digital Voice HD phone + Smart 2 = Landline unable to make or receive calls.
I did the check on the hub manager and there is still nothing. I will contact BT. Thank you for your suggestions
Message 12 of 12
I just had this same fault display on my Advanced Digital Home Phone.  But may have a solution
It claimed 'no internet connection is available' but oh yes there is as I'm using it to type this.
The Smart Hub 2 said  the phone was registered and connected.
So I deregistered it and reregistered it and it immediately asked about downloading new software (takes a few minutes) and then guess what it starts working again.
So the faults appear to be
  1. Advanced Digital Home Phones turn themselves off from calls if they think they need an update
  2. The design is woefully unsuitable for most people who wouldn't be able to figure that out
