Message 2 of 5
BT FFTP, HomeHub2 and Fortigate 60F with Multicast enabled ... still getting IPC6023
Hello ... getting desparate ...
I've got BT Full Fibre (FFTP) and upload/download speeds are great ... BT Home Hub2 all working fine - including digital TV channels 399+
I want to utilise a Fotigate 60F as my firewall device as I have work-related subnets at home ... I havne't even started on them - this query is basic functionality ..!
I have read many post about using a 3rd party firewall device and I have a few configurations - all with the same result; I cant receive any of my digital channels ... general browsing, etc is still working fine, just digital TV channels.
I thought it was simply IGMP not being enabled on my Fortigate but it seems its a bit more involved.  I have psoed a similar quiestion on Fortigate's forum ... no response yet.
At its simplest here is where I am up to...
- Configure the BT Home Hub 2 as a simple "modem"
-- I achieved this by:
--- keep WAN port connected to ONT/modem
--- turning off wifi
--- turn off DHCP
--- configure IP as 192.168.1.254/255.255.255.0
--- configure port-forwarding to 192.168.1.253 ports 1.65535 TCP/UPD - (192.168.1.253 is my Fortigate)
--- configure firewall as "Disabled"
On the Fortigate I have the BT Home Hub2 connected on the internal switch ports alongside my TV/Lounge ... all are on the same 192.168.1.0/24 subnet
The TV can "see" the internet all appears well - except I dont get any digital channels (399+)
At the Fortigate (FortiOS v6.4.4 build1803 (GA)) I have a Mulitcast Policy ALLOWing Protocol=IGMP for all interface on my "Home Network" ...  I have enabled SNAT
At the FortiOS command line I have also enable igmp-snooping (or so I think!) ...
HUDFORTI001 # config system setting
HUDFORTI001 (settings) # set multicast-forward enable
HUDFORTI001 (settings) # set multicast-ttl-notchange enable
HUDFORTI001 (settings) # end
HUDFORTI001 #
... but is it going to be a lot more involved than that ..?
HUDFORTI001 # diagnose ip multicast status
PIM ON Assert: ON Socket in use: TRUE
HUDFORTI001 #
... do I need to setup an entire PIM Sparse Mode configuration with Rendezvous Points, etc etc ..?
... any help on this would be gratefully appreciated ... lots of head-scratching right now and dont want to go back to just the Smart Hub2 without the Fortigate - for many reasons !!!
Many thanks,
Charles K
4 REPLIES 4
Message 1 of 5
BT FFTP, HOMeHub2 and Fortigate 60F with Multicast enabled ... still getting IPC6023
--- turn off DHCP
HUDFORTI001 #
HUDFORTI001 #
Many thanks,
Charles K
Message 3 of 5
Re: BT FFTP, HomeHub2 and Fortigate 60F with Multicast enabled ... still getting IPC6023
For FTTP there is no modem within the Home Hub. The ONT performs that function. As the Fortigate is a router just connect it directly to the ONT and set up a PPPoE connection.
For multicast see HERE.
Message 4 of 5
Hi @pippincp  ...
I tried as suggested ... Internet up/downloads all working OK ...
ONT is plugged into "WAN1" port on Fortinet ... TV/lounge on port3 of "Internal" / Home network ...
I set my mulitcast policy as described ...
HUDFORTI001 # config firewall multicast-policy
HUDFORTI001 (multicast-policy) # show
edit 1
set uuid 786d728e-6acb-51eb-5b7d-cd25a229c08b
set name "BT.IGMP.Allow.TV"
set logtraffic enable
set srcintf "wan1"
set dstintf "internal"
set srcaddr "all"
set dstaddr "all"
set protocol 2
next
end
... I reset my set-top box ... checked for Software and Apps updates ... all OK.
Still getting IPC6023 errors for channel 399 and beyond ...
Any ideas ..?
Message 5 of 5
I rather suspect you are in a minority of one with that device on here, you might get a better response on a Fortinet forum if there is one.
