Message 1 of 4
BT Smart Hub 1 Hub Manager - Laptop missing
I Have realised that my Laptop does not appear as a device on my Home Hub Manager.  I have read the similar posts but none appeared to help with my problem.  I am writing this post on my laptop, so it is connected!
Any help gratefully received.
3 REPLIES 3
Message 2 of 4
Re: BT Smart Hub 1 Hub Manager - Laptop missing
the device list, if you have read other posts, is not the most accurate or reliable so as long as your laptop is connected and working ok then I would not be bothered
Message 3 of 4
I agree with @imjolly  but if it bothers you that much then you could try a factory reset, just remember to turn off smart setup when it restarts as it will have been re-enabled
What is Smart Setup on the BT Hub? How can I turn it on and off? | BT Help
Message 4 of 4
Many thanks. Now that know it is not reliable, I will not bother.
