Message 11 of 16
Re: BT FTTC Availability not showing up? HELP !
it is openreach that need to update system and only way is to keep checking until you see available
Message 12 of 16
Yes at the moment I have 1 MBPS upload speed so to be honest ANYTHING higher than that will be insanity for me 😂
But I am looking for either, I just want to know an ETA
Message 13 of 16
Yes I have been checking for the past month, but I'll keep on it! Just checking, it's ultra fast FTTP I'm looking out for right?
Message 14 of 16
just keep running the checker and looking for WBC FTTP to show available - currently showing waiting list
once you see available then phone 08005874787 - FTTP Team
Message 15 of 16
Thanks so much for your help! Do you know how long this normally takes or is it 'how long is a piece of string' to how long the list is?
Message 16 of 16
Unfortunately it's the second option. No-one knows.
