Message 1 of 6
BT FTTP 900 Speed drops to 90MB, router restart fixes it
As in the title my speed drops to 90MB after a few days but restarting the router fixes it, anyone else have this problem?
5 REPLIES 5
Message 2 of 6
Re: BT FTTP 900 Speed drops to 90MB, router restart fixes it
don't know if you used search before posting but thread about similar problems
https://community.bt.com/t5/BT-Fibre-broadband/BT-Fibre-900-Upgrade-Smart-Hub-2-upload-throttling/m-...
Message 3 of 6
Try a third party router.
A known issue with the 910 / 110 package mate.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 4 of 6
any recommendations? I have got an Asus ac86u but I'm pretty sure this was doing the same so I've got to send it back.
Message 5 of 6
That should be up to the job easily mate.
Unless its faulty of course.
Message 6 of 6
could it be that we are on a 50-60m cat5e cable from the fibre line in? because i've got the new AX82U and its the same.
