Message 1 of 1
BT Fibre 2 FTTC and Google Nest Wifi
Hi looking to change from current ISP as I’m having issues with my home network. I would like to know if any BT customers have successfully managed to set up Google Nest WiFi with BT FTTC Broadband.
I believe I should be able to buy an Openreach modem to connect to the line coming in and plug in the Google Nest WiFi router in with the relevant PPPOE settings.
Has anyone else got this successfully and consistently working. My current ISP Sky use MER which Google doesn’t support and I’m getting Double NAT issues even with WiFi and DHCP switched off on the Sky router. Network is really glitchy.
Thanks in advance
