Message 1 of 13
BT Fibre 2, Incorrect profile
Hi, i have recently had my Fibre 2 broadband activated, but the max download speed it is showing that i can get is 50MB. The rest of my street can obtain 70MB odd when i check their address. I think i might have been put on the wrong profile, 55/10 instead of 80/20.
Please can someone help? Thanks.
12 REPLIES 12
Message 2 of 13
Re: BT Fibre 2, Incorrect profile
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 13
Message 4 of 13
Message 5 of 13
You certainly appear to be on a 55/10 profile.
Message 6 of 13
Message 7 of 13
Yeah thats what i thought, my line should support a max of 80 according to https://www.broadbandchecker.btwholesale.com/#/ADSL.
should i be on the 80/20 profile?
Message 8 of 13
You speed range is 80/67mb so you could be anywhere inbetween   however your attainable according to hub stats is only 63mb
Phone CS 150 and get changed to fibre 2   I would check MYBT and see what it sYs your package should be
Message 9 of 13
I am on Fibre 2, i have spoken to BT customer service but all they keep telling me is the max i can get is 50, but they dont explain why the rest of my street can get 70 odd and also how on my previous broadband provider i could get higher than 50 as well.
so i just wanted to check whether it was a profile issue but they didnt seem to know what that was
Message 10 of 13
They are talking  nonsense, your hub stats show you can get 63M and that you are capped at 55/10.
