Message 1 of 10
BT Fibre 900 + Archer c7 + ipv6
Hi Guys
As the title suggests .. is Activating IPv6 on my Archer C7 as easy as I "Think" it is
(PPPoE + Username = ([email protected]) + Password = BT) + "Save"  ..
***UPDATE***
I found this when searching >>>  (Does this still Hold True / Correct ??? )
IPv6 - *Enable*/Disable.  Enabling gives the following options:
- IPv6 Connection Type - choose from Dynamic IP, *PPPoE*, 6to4 Tunnel, or Bridge.  If PPPoE is selected it asks whether to use the same account as IPv4 - *yes*
- Get IPv6 Address  - choose from Stateful, Stateless, *Non-Address* or Auto
- Prefix Delegation - *yes*/no
- Obtain DNS automatically - yes/*no**Use Google's IPv6 DNS server addresses as follows:  primary - 2001:4860:4860::8888 and secondary - 2001:4860:4860::8844*
- Assigned Type - choose from ND Proxy, SLAAC+Stateless DHCP, DHCPv6, or *SLAAC+RDNSS*
- Firewall Rules - *none required*
Keith J
9 REPLIES 9
Message 2 of 10
Re: BT Fibre 900 + Archer c7 + ipv6
Well, I threw Caution to the Wind & tried out the Above ..
Result = Zip.. Zero.. Nada.. Nowt.. Nothing  Will not Connect
However, with a little bit of Playing around (Blindly I might add)  I changed the Connection type from PPPoE to 6to4tunnel  & BOOM !!!!!
Connection Established Everything running Smoothly  & (whether this is anything to note I dont know)    I got  Rather a Big "Speed Bump"  in the process.
When I originally got Fibre 900 my speeds were in the high 800's to low 900's over the months (4 actually)  the speed have been dropping consistently giving me low 600's to high 500's ...
Changing to an IPv6 connection appears to have "Bumped this up" by about 100 mbps (Now high 600's to low 700's) ..
Still Puzzled as to WHY the PPPoE settings on IPv6 wouldn't connect though
THOUGHTS Gentlemen ?????
Message 3 of 10
Try using these settings recommended by tp-link for BT:
https://www.tp-link.com/uk/support/faq/2942/
The difference seems to be the DNS setting.
Message 4 of 10
@TheSeasider  6to 4 Tunnel isn't native IPv6, it is just IPv6 being tunneled over an IPv4 connection.
Try dynamic IP rather than PPPoE for connection type and then DHCPv6
DNS settings are OK as BT doesn't have IPv6 DNS servers and just uses IPv4 DNS to give IPv6 addresses.
Message 5 of 10
licquorice,
On my "WAN" page I dont have an option fer Dynamic DNS all my options are :-
DHCPv6
Static IPv6
PPPoEv6
SLAAC
tunnel6to4
on my "LAN" page I have
DHCPv6 server
SLAAC
Message 6 of 10
Select DHCPv6 on the WAN and SLAAC on the LAN
Message 7 of 10
Yup Tried that as well .... Zippo / Zero / Nada !! ... Frustrating the Hell outta me is this thing !!
Message 8 of 10
It's quite possible the Archer doesn't support BT's /56PD implementation of IPv6
Message 9 of 10
Licquorice, A Question my young man.....
Is there actually ANY BENEFIT in using IPv6 over IPv4 ??
I ask coz I'm about to fling this Bloody Archer C7 down the Garden like a Frisbee !!!! (& Spend some Hard earned Dosh on one that DOES support IPv6 ) .. I'm pushing 65 here so "Gaming" is a total Foreign Land to me  IPTV I can (Just) cope with
Cheers for your input BTW VERY MUCH Appreciated
Message 10 of 10
I like the young man bit, being somewhat older than yourself.
There isn't really any advantage to IPv6 over IPv4, its only reason for existence is lack of IPv4 addresses. There are currently extremely few sites that are IPv6 only although that will obviously change as time progresses. In theory, IPv6 is slower than IPv4 due to the extra overheads.
