Message 1 of 14
BT GFAST going slow and intermittent
I ordered GFAST in March &used to get 200Mbps d/l & 30mbps u/l.  After an engineer visit he changed ports and now it's constantly going down & is 150 / 24 mbps. My neighbour still gets 195/29. BT support. says no fault /no help. What is the best way to get back original speed & what my neighbour is getting.  I should not be checking fiull day what speed I am getting. At times I am getting 100/ 15 mbps but by the time you call them its back to 150mbps which is minimum guarantee so no support.
Was wondering if someone here can help and get some consistency in speed...
My neighbour seems to be happy and never complain about speed. Seems like I am paying extra 25 pound for a service which is not as reliable as I was told and thought of.
Can someone help ?
Thanks in Advance.
Sush
13 REPLIES 13
Message 2 of 14
Re: BT GFAST going slow and intermittent
Can you post your router stats from Advanced settings/technical log/information.
Check for noise on your line. 17070 option 2, best with corded phone, you may get a background hum with cordless.
Message 3 of 14
Product code:Smart Hub 2
Serial number:+093678+1937004236
Firmware version:v0.26.04.04227-BT
Firmware updated:Tue May 25 08:43:11 2021
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:10 days,02 Hours40 Mins07 Secs
Data rate:26.875 Mbps / 197.123 Mbps
Maximum data rate:26.129 Mbps / 194.704 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:3.1 / 3.1
Line attenuation:0.0 / 39.1
Signal attenuation:0.0 / 39.1
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:86.7 GB Uploaded / 270.8 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:My-Zone
2.4 GHz wireless channel:Smart (Channel6)
5 GHz wireless network name:My-Zone
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:F0:86:20:70:6B:21
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017
No Noise in TEST with option 2.
Message 4 of 14
according to stats your connection is 197/27mb and has been for last 10 days
Message 5 of 14
That's a BUG 🙂 .  I tried this already.  this is the stats when you get the modem booted and get connected........This then remains the same always.never changes.........but your speed  keeps on changing...
Message 6 of 14
This is the latest I am getting on my mobile now.
Weekdays is 155/24///  can post tomorrow.
Message 7 of 14
The connection speed will not change, however the download speed will vary depending on how many people are using the backhaul connection to the cabinet, as its shared between all users.
So if its the download speed that you are measuring, then that explains the variation.
Also, if you are measuring over a wireless connection, then that will be all over the place, due to the amount of interference.
Message 8 of 14
And this is what I used to get one month back...before I as upgrade........... I am, on stayfast of  150 mbps
Message 9 of 14
 This is what my package says
Message 10 of 14
I agree.  I have measured with speed with a cable connection to desktop as well.  However, in any case ...BT Check on App  should not change " Speed to HUB".   ... BT Guarantees "Speed to HUB" which is the concern here. Internal connection ..devices,... wireless etc can be a reason.. but I am asking why " Speed to hub " is fluctuating.
