Message 1 of 6
BT Hybrid Connect
Hi Community
Been reviewing eBay recently and found that people on there are selling their BT Hybrid Connect device.  I currently have BT halo 2 and wondered if I purchased one of those devices from eBay would it work with my current package? or is the device tied to the sellers BT halo 3+ subscription?
5 REPLIES 5
Message 2 of 6
Re: BT Hybrid Connect
Hi @j0nezjm76uk   Why would you pay for one when they are loaned free with the required Halo3+ subscription.
Message 3 of 6
Hi thanks for the reply. BT are asking for an extra 4 pound a month over 24 months which is an extra £96 over the two years. whereby if i get one from ebay is it will cost me £25. depending if the device isnt tied to the sellers halo3+ subcription.
Message 4 of 6
@VeteranISPUser Hi thanks for the reply. BT are asking for an extra 4 pound a month over 24 months which is an extra £96 over the two years. whereby if i get one from ebay it's will cost me £25 outright. depending if the device isnt tied to the sellers halo3+ subcription.
Message 5 of 6
You clearly didn't read @@VeteranISPUser  reply. A Halo3+ subscription is required for it to work.
Message 6 of 6
@licquorice Thanks for pointing that out.  Understood.  Thanks for the info.👍
