Message 1 of 19
BT SMART HUB 2 Firmware 026.03.01826
so hub has just updated to this anyone know what this firmware brings to the party?
18 REPLIES 18
Message 2 of 19
Re: BT SMART HUB 2 Firmware 026.03.01826
Just got this firmware update yesterday, out of the blue...?
I'm on fttc., and on a waiting list for fttp. Existing hub has a digital voice port  which is taped off.
The biggest visible change on the HomeHub pc dashboard  is an option for future use with fttp.
Message 3 of 19
not seeing anything new had the phone button on the dashboard b4
Message 4 of 19
Then presumably you are already on fttp?
Have not noticed the fttp option before....In fact have been told that a new Smart Hub 2 will be required for fttp". (Seems that there are 2 Smart Hub 2 versions in use). If so, why does the fttp option show?  Or have I been misinformed?
Will check again with BT.
Message 5 of 19
There are definitely 2 versions of SH2. FTTC version with 4 LAN ports and FTTP version with 3 LAN ports and 1 WAN port. My firmware hasn't updated yet, still on v0.24.04.11017
Message 6 of 19
Hi have this version... FTTP version with 3 LAN ports and 1 WAN port.
Message 7 of 19
Like @Ribblelancs  my firmware has updated and now showing FTTP in advanced settings then information
Message 8 of 19
@licquorice ,
This needs looking in to. It’s still not clear re: what the new firmware does.
My Hub has 4 LAN ports. So why is the fttp status now shown in the information display? ....as pointed out by self and @imjolly
It was not there on the previous issue.
Are the Smart Hubs 2 type A and B, being upgraded? Seems pointless issuing new firmware for type A and B, if only one version is fttp compatible.
Message 9 of 19
so in addition to this new option..
everything seems to be running faster now
Message 10 of 19
I’m confused, there must be 2 SH2’s. Someone reported v0.26.03.01286-BT firmware the other day.
My SH2 has Red Wan port and I have FTTP and the firmware is at v0.24 ....
