Message 1 of 4
BT Smart Hub 2 as Modem only -- views on this config change
Hello,
Has anyone any experience of using this suggested config change to the BT Home Hub to make it work as Modem only.
https://www.lifeadvuk.com/post/using-bt-smart-hub-as-modem-only
it appears to work OK for me but i am a little concerned about any security breaches in this config that uses the DMZ feature.
JOHNW
3 REPLIES 3
Message 2 of 4
Re: BT Smart Hub 2 as Modem only -- views on this config change
It will work, it's a bodge, it isn't putting the BT hub into Modem mode, it doesn't have a bridge mode. The hub is still routing and natting, it is simply connecting 2 routers together.
The only reason to do it would be to maintain Digital Voice capability which requires the Smart Hub2 to operate.
Message 3 of 4
any details on how to put smart hub 2 in to modem mode
thanks
Message 4 of 4
It doesn't have a modem only mode.
