Message 1 of 7
BT Smart Hub 2
I have just received a new  BT Smart Hub 2 in the post in preperation for a move to fibre on the 17th.
I am trying to find some technical info about this hub but it is sadly lacking.
I haven't used a BT hub for ever. My current Asus DSL AC68U hub supports Guest wifi accounts and up to 32 Port Forwarding addresses.
Can I expect this new BT hub to at least match that or should I send it back? No point in me keeping it.
Anyone know?
Thanks all.
6 REPLIES 6
Message 2 of 7
Re: BT Smart Hub 2
there is no guest network  stick with what you have and are used to
Message 3 of 7
Re: BT Smart Hub 2
Keep the hub as a spare.
Message 4 of 7
Re: BT Smart Hub 2
Thanks for the insight. I figured as much.
Message 5 of 7
Re: BT Smart Hub 2
Got it. Thanks for the suggestion. I can't see me ever using it though.
Message 6 of 7
Re: BT Smart Hub 2
Its always handy if you have a fault and customer services insist you connect a BT hub.
Message 7 of 7
Re: BT Smart Hub 2
Sure. Bu it's back in the packaging and under the stairs now.
