Message 1 of 9
BT smart hub 2 bedtime settings
Hello. I am trying to set ‘bedtime’ on my daughter’s laptop in the My BT app but it will not save. I enter all the details and all looks fine but if I log off and on again they will all be blank. I have also tried renaming the laptop but it soon reverts to its original name so again nothing saves. Also nothing appears in ‘offline devices’ when I turn the laptop off. Am I doing something wrong? Or does the setting just not work??
Help appreciated!
8 REPLIES 8
Message 2 of 9
Re: BT smart hub 2 bedtime settings
Can you detail the steps you have followed and whether you are using the iOS or Android App to change these settings?
Message 3 of 9
Hi. I am using the iOS app.
I open the app and go to ‘your Wi-fi network’ then ‘control Wi-fi access to your devices’.
Select the laptop in question.
Then I either ‘rename’ and give it a sensible name.
Or
Press ‘set times’ under bedtime and enter the times and press ‘save’.
It all looks like it has worked but if I restart the laptop or restart the app the settings revert  to default.
Interestingly I just tried again and saw the error ‘failed to update access controls’ which it was not doing before.
Appreciate the help on this!
Message 4 of 9
Have you enabled the "Pause wifi-access at bedtime" option as you can't make any changes to the bedtimes until that is done?  Also if the device in question is using a randomised MAC address each time it connects then it able to circumvent this control anyway.
Message 5 of 9
Thanks. Yes I tried that. In face just saving and going back then forward again is enough to clear the settings. It’s like they just don’t save.
Message 6 of 9
See this thread which may be similar to your problem
disable wifi at bedtime - BT Community
Message 7 of 9
Hi all. Appreciate the responses but none worked 🙂 I called BT who suggested a factory reset of the smart hub and this did in fact fix the issue.
Message 8 of 9
Glad you got it working, useful to know that sometimes the only option is a factory reset
Message 9 of 9
Thanks for letting us know you got this sorted @Geoffers1 .
Cheers
David
