Message 1 of 5
BT Smart Hub to ONT connection
Hi
I'm lucky enough to be moving to a new build soon with an ONT box
My existing BT Smart Hub at my current house does not have a red WAN marking on Port 4
Will it work if I plug the ONT into port 4 and then my other devices into 1,2 and 3
Or am I going to need a newer router from BT ?
4 REPLIES 4
Message 2 of 5
Re: BT Smart Hub to ONT connection
You will need a new hub that has a WAN port. There are 2 variants of the Smart Hubs. Your existing Hub  has 4 LAN ports.
Message 3 of 5
OK, thanks I will ask BT when the time comes
Do you happen to know if they send me a Smart Hub 2 instead of a Smart Hub are the feet the same size/distance apart ?
It's just that I have a bracket to mount it on the wall
PS do you know if they take the old one back ?
Message 4 of 5
Don't know the dimensions of the SH1, but if its any help, the SH2 feet are at 155mm centres.
Yes, they should provide a returns bag.
Message 5 of 5
Great. Thanks
I would say mine are about 160mm between centres, so close but I might need a new bracket
