Message 1 of 4
BT Sport App on my Samsung Smart TV
I'm on BT Broadband and I'm in the process of cancelling BT Sport which I watch through Sky. (To dear)
I'm just about to receive a BT Sim only (100gb) which has the  BT Sport App Included.
Will I be able to watch that on my New Samsung tv which has the sport app on it.
Have seen different reports.
Hoping someone can help an old novice.
3 REPLIES 3
Message 2 of 4
Re: BT Sport App on my Samsung Smart TV
If you get BT Sport bundled with a mobile subscription it's only for small screen access but i believe that you can upgrade for around a fiver a month if it's through BT or EE
Message 3 of 4
With an EE subscription you can pay for the large screen add-on, which would allow you to watch on your Samsung TV (as long as it's 2015 model or later).
With BT Mobile, there's no add-on available. You can only use the mobile app. If you want to watch BT Sport on your Samsung TV, you'll either need a monthly pass (£25 a month), or have BT Broadband and take out one of the options on that (starting from £15 a month).
Details: https://www.bt.com/sport/buy
Message 4 of 4
Many thanks.
