Message 1 of 16
BT Sport - Error code IPC6023
Having issue getting all BT Sports channels through You View box. Done all the checks as advised via help and even run a new cable between router and you View box with no joy.
Spoken to BT three times now on last call I was advised there is a known issue and currently waiting time is 7 days.
Anyone else experiencing same issue at this time?
15 REPLIES 15
Message 2 of 16
Re: BT Sport - Error code IPC6023
UPDATE - Unfortunately missed tech teams call. Followed instructions on voicemail, turned router off (which I’d already done numerous times), then had to reset You View box to factory setting which loses all your recorded programmes (annoying).
And guess what problem still exists 😡, why am I getting the feeling  this is going to drag on !!!
Message 3 of 16
IPC6023 is a well known network error, it means loss of Multicast packets (which BT TV relies on) and can be be due to a fault on your home network and outside your home.
Press the Help button on your YouView remote control and follow the diagnostics on there, if the problem persists (50/50 chance that it will) then both @DarrenW  & @Gemma_P  are familiar with this error
Message 4 of 16
Thanks Les
Tried all the help advice, I even ran a new cable between router and You View box, but still getting same error. Guess I have to wait for BT to get back in touch with me.
Message 5 of 16
I don't think you'll have to wait that long.
I tagged DarrenW and Gemma_P in my last post, from what I've seen on this forum they're both pretty quick to respond and both seem to know their stuff.
Message 6 of 16
I share your frustration. I'll certainly not rush to reset to factory settings. Been trying to call BT but can't get through. So annoying when everything works fine one day then nothing the following.
Message 7 of 16
@BobR6
Reading your original post, I would hazard a guess that powering down your mini-disc for a minute or so will resolve your problem
Message 8 of 16
Hi @OscarB33 and @BobR6 I'm really sorry to see you're having problems with your BT Sport channels.
Do you have a full-fibre line? If you do can you try a reset on the Openreach Hub by following the steps on this link and let me know if that helps?
Neil
Message 9 of 16
Hi Neil
Yes that’s worked. Thank you very much.
Message 10 of 16
Hi @OscarB33 That's great, I'm glad it worked for you.
Cheers
Neil
