Message 1 of 3
BT TV Box Pro - Wired or wireless?
Hi,
I understand the delay on live sport using BT TV Box Pro is minimal (2-3 seconds) due to the fact it uses the multicast system. Will this still be the case if I use the BT TV Box Pro using a wireless connection? Or is it better to use ethernet cable connection in terms of minimizing delay?
2 REPLIES 2
Message 2 of 3
Re: BT TV Box Pro - Wired or wireless?
It's always preferable to use a wired connection where possible.
Message 3 of 3
Both options will have the same delay.
The delay is in the system before it gets to your router.
@urbanlegend179wrote:
Hi,
