Message 1 of 5
BT TV Pro box won’t connect to WiFi
Received BT TV Pro box today to go with my BT Broadband. But the box refuses to connect to my BT Home Hub over Wi-Fi. Weirdly it will connect to my Meraki Wi-Fi.
I know the password for the Wi-Fi is correct and there’s no Ethernet cable plugged in. It just keeps stating ‘cannot connect’.
4 REPLIES 4
Message 2 of 5
Re: BT TV Pro box won’t connect to WiFi
Turn off Smart Setup on the hub.
Message 3 of 5
That did not work.
Message 4 of 5
Message 5 of 5
Hello, I don't know how this community works but I have exactly the same issue. The Pro box has worked perfectly since I had it and suddenly it can't connect to the WiFi.
I see the previous contributor went to private messages which doesn't really help me.
Does anyone have any ideas?
