Message 11 of 15
Re: BT TV not connecting to internet
Ignore the following. I just noticed the link in your previous email 😂
@NeilOHow do I choose to keep my recordings? When I select 'factory reset' it warns me that I will lose all recordings. Then I have the option of reset or don't reset.
Message 12 of 15
@stresiden, no worries, if you do the reset using the buttons on the TV box rather via the remote you can keep the recordings.
Anonymous
Not applicable
Message 13 of 15
@stresiden
Follow the link supplied by @NeilO and checkout step 3
Message 14 of 15
@NeilO Seems to have done the trick. Many Thanks! 😁
Message 15 of 15
@stresiden no problem, I'm glad that worked Smiley Happy
