Message 1 of 12
BT Virus Protect and Chromebooks
Hi there - BT Virus Protect does not seem to be compatible with HP Chomebooks and their operating system - is any way around this?
11 REPLIES 11
Message 2 of 12
Re: BT Virus Protect and Chromebooks
which model do you have? some models support the running of Android apps, click the link for a list of them.
https://www.chromium.org/chromium-os/chrome-os-systems-supporting-android-apps
Message 3 of 12
Hi Les
Thanks for your reply. It’s an HP Chromebook 14 db0000na.
 I had a look at the link you posted but couldn’t tell if it was there.
Regards
Mat
Message 4 of 12
Try downloading it from the Google Play Store, you won't be allowed to if it's not compatible and you will receive a warning instead
Message 5 of 12
Why do you need it. Chromebooks have an inbuilt virus protection provided by Google via the cloud.
Message 6 of 12
Thank you so much for the advice. I have read it has built in anti virus. Let’s hope it works!
Message 7 of 12
Thank you - you are right of course!
Message 8 of 12
IT Works fine I have had a Lenovo Chromebook for several years and never had any Problem.IT is great for browsing the net. So when I don't need to fire up the PC and wait for it to boot up I just fire up the Chromebook and straight onto the web,
Message 9 of 12
That’s good to hear.
I had a nice guy from HP support tell me all about the inbuilt virus protection. Good aftersales customer service!
Message 10 of 12
Thank you for the advice - the in built virus protection seems to be working fine.
