Message 1 of 4
BT Whole Home Discs (White & Black)
Hi,
Can i please ask if there is any difference between the white BT discs and the Black BT discs that are offered part of the Halo 3?
I already have the white once, and not sure if the neewer ones are different?
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: BT Whole Home Discs (White & Black)
The black discs are for Complete Wi-Fi (as opposed to Whole Home Wi-fi) and the two are not compatible.
Message 3 of 4
Thanks Les,
Any idea if they both work the same?
As Bt are wanting £12 extra a month for complete wifi - and if they work the same i see no poit in the upgrade - as not really intrested in the other offerings that come with the Halo offering.
Message 4 of 4
No, they don't work the same way but if you've got a good working Whole Home system then you don't need Complete Wi-FI
